having fps problems help
UniqueLegacyy
213
wondering why im getting kinda low fps in games like bf4 cs:go and stuff like that i have a geforce gtx 780 with a amd a8-5600k apu with radeon(tm) for a CPU and 16 GB of ram so i don't know y im getting low fps
Your processor is more than likely holding you back. You have a very strong dedicated GPU which should not be paired with an APU. The a8 is good if you don't plan on adding a dedicated graphics card because as a stand alone CPU they are not very good.
I recommend getting a new CPU which will require a new motherboard as well.
