Question Having issues with monitor: LG 27GR83Q
Dec 29, 2024
I've been having a issue in the last two days of using my computer, in relation to my one of my monitors seemingly shutting down once or twice a day now. What will happen is my fans on my computer will start running fast, and then after roughly 5-10 seconds, my newer, LG 27GR83Q monitor will shut down. This has happened while I was playing games, and it has also happened when on low level browsing of social media with nothing intensive running as well. On the several times it has occurred, when I try to turn the monitor back on, it will stay on for a few seconds, and then proceed to shut down like before. However, if I adjust the DisplayPort or Power cables at the back of my monitor, it appears to fix the issue for a few hours or so, but will always reoccur some time later. I wasn't able to get a great video, but this imgur should show what it is like right before it shuts down: View: https://imgur.com/a/TQcDkek
. I have owned this monitor for roughly a year, but started using it 6-7 months ago, a few days after I set up my new computer system. The only other issue I've had that could be related is that sometimes when the computer came off sleep, it seemed to take a while for keystrokes to load into the screen a few seconds after turning back on, but this might be an unrelated issue. Is this related to the wires of my computer, or is the issue somewhere else? I tried reconnecting the wires connecting the PC to the monitor on both ends, but it hasn't led to a permanent solution.
RMA the monitor. Since whatever it's issue is, it falls under warranty.
If all your monitors would shut off at the same moment, then issue would be with PC (GPU). But if it is the only one behaving such, RMA it.
I'll make an attempt tomorrow morning when the support comes online, but my worry is I received this monitor a bit longer than a year ago, and the warranty is only for a year. I did look up and see that my credit card I purchased it with might have an extended warranty up to two years, so I might be able to get my money back at least.
Bumping again. I've contacted LG Support, and its unlikely they will RMA the monitor since its a few weeks out of warranty, and I was hoping to try everything I can before getting the repair done, which will cost most of a new monitor anyways.
Well, testing the monitor behind 2nd PC can show if it is monitor issue.
Another option is plugging the monitor into another display port in the GPU (e.g switch two monitor ports around). If issue still persists, it would be monitor issue. But if issue goes away and now the 2nd monitor catched that issue, then it would be that specific display port on GPU.
But it seems that it is monitor issue, because monitor itself turns off. If the video signal from GPU would cut off, monitor would show "no signal" instead.
Planned obsolescence. Sadly, norm as of current date.
Further reading: https://en.wikipedia.org/wiki/Planned_obsolescence#Contrived_durability
IMO, so stupid. Just because device has been used 2 years (usual warranty period), it is designed to last slightly more than the warranty period is. All that, to force people to buy and buy and buy new stuff manufacturers produce (to increase sales).
Reactions: open_Target
