Having problem with new motherboard
ZEEDEESINGH
Commendable
Jun 14, 2016
16
Hi. All
I've built new pc. It's i7 6700 k 4.0 GH, MOTHERBOARD IS gigabyte z170- d3h, ddr4 ram.
My problem my full complete setup working fine. But when I tried breadboard setup before complete build up, I noticed that without RAM there is no beep sound and motherboard light turn on for few seconds then goes off without any beeps. But when I instal the RAM, there is a regular beep sound and all works fine. I am not sure if MoBO is faulty or its just normal to have no beep sound without RAM, as was earlier motherboards when you would get a continuous beep if RAM is faulty or not installed.
Thanks
So I presume that no sound without RAM is fine. Though ram installed it gives normal sound and works as perfect as it should be. I'm just curious to know as I bought MoBO a couple of days back only and can be replaced if it's a problem. But I'm not sure if it's a problem or not. There's no detail available on website or hardcopy manual
No problem with that, as long as you can run OS fine without any problem, i can say it's absolutely fine.
Thanks dear...your reply will sure calm me and cool down my anxiety. Thanks again for your help
MERGED QUESTION
Question from ZEEDEESINGH : "Can anyone help with my motherboard"
