having problems with sony vaio
mazda rx3
4
so i got this second hand sony vaio cheap, it had no drivers on it my friend thought it was ruined, i got some drivers, but here's the problem, after i download wireless driver, i restart it or turn it off, and when i turn it back on i am forced to use start up repair, and that doesn't fix it so i have to sys retore to earlier time, im using it atm, and im trying to figure this problem out but no success.
if anyone can help me fix this problem for good, i will paypal you $40
also when i go to play arma2 i get the message, "display adapter does not support format d24s8 for x8r8g8b8
if you could please help me that would be really good thanks
the wireless one is working atm, but if i restart it won't turn back on unless i sys restore it
also need pci device, and ethernet controller, no drivers for them
sve15118fgw sony vaio e series
Intel® Core™ i7-3612QM (2.10GHz, Turbo Boost to 3.10GHz)
4GB DDR3 RAM
750GB HDD
DVD SuperMulti Drive
15.5 inch HD (1366 x 768) VAIO™ Display, LED Backlight
AMD Radeon™ HD 7650M
10/100/1000 LAN, 802.11 b/g/n WLAN, Bluetooth®
Intel® High Definition Audio
1.3 Mega Pixel "Exmor for PC" Webcam
Digital Media Card reader
HDMI (1), VGA (1), USB 3.0 (1), USB 2.0 (3), RJ-45 (1)
Windows® 7 Home Premium 64-bit pre-installed
specs, that website run that game dot com said it can run arma2 i'll be happy if i can get the game to work
