Hey guys,
i have an Intel core 2 duo E8500 3.16 GHZ 6MB cache (can be overclocked) in a Gigabyte g41MT-S2P motherboard with ram 6GB DDR3 Kingston.
To start with when i enter bios to overclock my processor up to 4.0 GHZ for example i turned off the easy energy saver technology in the motherboard first then when i try to overclock it to 4.0 GHZ with 1.3V Then i save and exit bios but when i open core temp to check if the frequency nw is 4.0 GHZ i found out that the frequency written is still 3.16 GHZ also when i chose my computer then entered right click then properties it's still 3.16 GHZ also when i entered " dxdiag " in run also written 3.16 GHZ so i want to know if it is overclocked but it doesn't write or something is wrong?
Note:
I use cooler master seidon 120v plus liquid cpu cooler
Thanks <3
Note:
Thanks <3
