HD 6870, Enough Power?! :[
Falcon904
8
Hello,
Recently i purchased a HD 6870 1GB, But i'm not sure if it will run on my PSU. I have a Diablotek 450w PSU with 12v/30A. For the card, 500w is recommended. I dont know if i would have trouble running it with just my DIablotek 450w? What you think?.
Well, this is what the PSU will do:
Scenario one: No boot.
Scenario two: There's a bang and some sparks, maybe some smoke, and in the worst case: A fire breaks out.
Why shouldn't of i purchased the HD 6870?.. I got it for a hell of a deal. 50$. I tested on friends rig, Works. Just making sure that if it would work on a Diablotek 450w. People are syaing that theres a really big chance that the PSU would blow and take components with it. Which im afraid of. Since it IS a cheap PSU. Just trying to find out if i would be safe on it untill i upgrade it?
I agree Diablotek is junk. And if it does fail, it might take out your motherboard and gpu or more
That said, it would probably "work" but please replace the PSU as soon as possible.
BTW Other then being last generation, there is nothing wrong with a 6870
Scenario three:
GPU Artifact
Harddisk Badsector
Motherboard fault
all above is due to lack of power and voltage out of safety range..
Hah, forgot about those.
