Question hd rgb fans not working with i cue?
Sep 29, 2019
i purchased a spec omgea case that came with 2 fans with rgb lighting and i downloaded the software and it recognizes that the fans are there and working but the leds in the fans are not in addition the led strip built into the case does not work they recognize they are there and i can even make profiles for the fans and case but no leds are turning on.
Sep 29, 2019
Vic 40
Ambassador
Are the rgb cables connected to the node pro at the back?
The node pro is connected to the rgb header on the motherboard?
Saw in that video two sata power connectors,are both connected to a sata power connector from the psu?
