hi,
I have a 1TB HDD and its works fine from last 4 year's
but last week I install win 8.1 free version then these 1 or 2 MB size partition has been created.
I switch on to my normal window 8 pro version but the 1 or 2 MB partion doesn't gone, even
I try to delete my C: drive partion and create them again but every time this non useable partion has created.
whats the problem I can't understand.
I try to remove or merge them with my right partiton without harm my OS and my files,Is there
any solution for this 1 or 2 MB partitons.
here the link:-
https://app.box.com/s/bjqqt2eovofswwu6esm0
plz give some idea to remove them.
thank you
here the link:-
thank you
