HDMI cable insertion issues
Ezenia
34
Hey,
I've never been able to insert a HDMI cable into my GPU (MSI Nvidia GTX 750Ti). I'm currently stuck using VGA because of this.
Is there anything I can do about this problem?
Photo of issue: http://puu.sh/s9HGI.jpg
Quality may be bad, but as you can see, there is something at the top that is preventing a normal HDMI cable going in fully.
Case: CiT1017
Motherboard: F2A68HM-HD2
You can try a slimmer HDMI connector:
https://www.amazon.com/Monoprice-10-2Gbps-Performance-RedMere%C2%AE-Technology/dp/B00AJHBMSS?th=1
You may just need to realign the motherboard to the case so you can get the connector a little farther down. Loosen the motherboard screws and all the PCI / I/O bracket screws. Plug in the HDMI connector, then tighten all the screws down.
You can also trim the I/O brackets around the connector if there is metal in the way. Obviously this will require some dis-assembly of the computer.
