HDMI output problem
thehig
31
I had my PC set up to duplicate displays, 1 to my monitor and a hdmi cable to my TV.
Randomly tonight the TV will no longer display anything, despite no settings or anything being changed.
Tried the obvoius, different HDMI cable, graphics drivers, HDMI socket (it plays the 360 in Hdmi fine).
I tried booting in safe mode, that kind of works, the PC monitor displays safe mode normally, but the TV displays it with a green background (instead of black) and just very noticeable the graphics are awful.
Changing resolutions does not do anything, It displays on nothing apart from 800x600 in safe mode with poor qaulity.
I'm out of ideas can anyone help.
Ps - My TV is an Orion 42" Plasma (old and dated I know, still does the job supports up to 1080i, 60hz refresh rate and max resolution of 1920x 1080.
Graphcs card is ATI Radeon HD 5450.
Connect your HDMI cable from your PC to another display device and see if it works. It might be a port issue. Just plug it into your monitor if it has a HDMI port.
If you know what you're doing, it could be as cheap as $10/£8. I'm not too sure how you would go about getting it fixed. Contact the manufacturer and see what advice they can offer you. Otherwise, just get a new TV 😛
I am not sure how you narrowed it down to the input on the TV but I have a thought if you have not tried this:
You said that the TV supported 1080i, not 1080p. Have you checked your driver software to ensure that your output is conducive to that resolution? In my research people have been successful with 1980x1080 resolution at 30 htz.
Just a thought
Makes sense to me! I just wanted to be helpful in case it was a resolution issue. Is there no other inputs to save you from buying a new TV?
