I have a laptop and I have added an external monitor that I connect with the hdmi port.
The native resolution on the monitor is 1360x768. But I prefer 1920x1080. I can set the monitor to 1920x1080 and everything looks good. So far no problem.
When the monitor is turned off and turned back on or when the hdmi port disconnects due to sleep, etc. and the monitor is reconnected the picture looks horrible. The resolution is still 1920x1080 but now it looks very fuzzy. I have to reset the resolution to the native and then again reset it to 1920x1080 and everything looks good.
I hate having to do this every time I turn the monitor on or every time the laptop wakes up the display. Obviously the monitor can display 1920x1080 with no issues but seems to have issues when it first comes on for some reason.
My laptop display looks fine all the time. It is an HP Evny 17 running Windows 7. The monitor is a TCL 24".
The only monitor the OS is using is the Generic PnP. When I have the external monitor connected there are two Generic PnPs (one for the laptop and one for the monitor) in device manager.
I think that is the key to the problem but I'm not sure. I have read about folks having this problem on Linux and having to set "Hot plug" to false for the monitor. So PnP I think is the same as "hot plug" but I don't know how to use a different monitor type or disable the "hot plug" on Windows.
Anybody have any ideas on what might be happening here?
