[SOLVED] HDMI to VGA adapter works with HDMI output, but not with USB-C adapter HDMI output
Cj-tech
Admirable
Jan 27, 2021
536
68
8,940
So, I have a newer laptop with a USB-C port that I have an adapter for HDMI and USB ports. This adapter works on TVs and other monitors, but not this older one.
The monitor doesn’t work when I have the HDMI to VGA adapter plugged into the USB-C to HDMI adapter (says “Input not Supported”). The laptop does detect the monitor, but nothing displays with the USB-C adapter. However, when I plug the HDMI to VGA adapter into the laptop directly, it functions normally.
I have a newer monitor, but I just wanted to use this one instead temporarily.
Photos:
With USB-C adapter: https://drive.google.com/file/d/1kTZyYL6Pnb6JPzSEJqJpXB3NVEya42Cs/view?usp=drivesdk
With laptop HDMI port:
https://drive.google.com/file/d/1_2eBrDVJqpkkR4oLQeufY2WgHrieQy83/view?usp=drivesdk
Monitor: Asus X203H
Laptop: Dell Inspiron 7386 2-in-1
Adapter: Hieracool Model #UCN3286
Any ideas on how to get the USB-C adapter working with the HDMI to VGA adapter?
Photos:
Monitor: Asus X203H
I am guessing, but I bet that the USB-C adapter doesn't provide the power required for the VGA adapter.
So, the adapter has a USB-C power input too. I just plugged a cable into that and it has the same issue.
Edit: I read about it having to be a thunderbolt adapter here. Also, this answer says that USB is digital while VGA is analog. I'm guessing that it won't be compatible. I looked up manufacturer drivers, but none are available (it's plug and play).
Ahah! This is genius: Betreff: Laptop cant connect to external monitor via USB-C hub - Dell Community
Problem solved! Just change settings in the Intel Graphics Command Center (like resolution, scale, and refresh rate).
