[SOLVED] Headphone output from motherboard rear panel or pc case front panel ?
worstalentscout
BANNED
Nov 1, 2016
323
hi,
which output will give better sound quality from headphones ?..............headphone output from motherboard rear panel or pc case front panel ?
should be the motherboard rear panel since there's 2 to 4 audio capacitors......and physically closer to motherboard's audio circuitry ?
hi,
It should be same as it comes from same chips, there are no separate circuits. Front ones could be a problem depending on quality of cables from MB to the case picking up some electronic noise.
hi,
