[SOLVED] headphones problem
GeorgeGod
141
Hello i just bought the hyperx cloud 2 headset and it working fine but the mic dosent work i search on the internet and i found out a video with tells to update the firmware version for it to work befpre i do that i chech the comments to see what they were saying and they all say it worked but for me no if you can find why please tell me
go into settings> system> sound and make sure that the mic is set to the input and it has a testing tool (also make sure the mice plug in plugged in to the mic port
