Heat & silent box to HD
G
Guest
Guest
Has anybody used a silent box with IBM 60 GXP hard disk?
Can I use a silent box and a IBM 60 GXP 60GB without destroying the disk because of the heat? Or can silent boxes only be used with a HD less than 7200 rpm?
<A HREF="http://www.quietpc.com/silentdrive.html" target="_new">http://www.quietpc.com/silentdrive.html</A>
According to the stats here, it can handle a three platter IBM 75GXP. Given that a 60GXP has 20Gb per platter (runs cooler) and its revolution rate is 7200rpm (as per recommended max speed for silent drives here, it should be fine.
I hope so cos I plan to put three of these drives with enclosures into my new system.
<b>
"Now drop your weapons or I'll kill him with this deadly jelly baby." :wink:
</b>
Thanks for the link - Nice review of silentDrive.
I've just checked the 60GXP specs. and it says it runs at 6.7 watt idle and between 5-55 C so it should work just fine.
Thanks again
