Help a first time builder out?
HeyImGodly
368
17
this will be my first time building a pc mainly because its cheaper,
I have a budget of about 1000 (including tax and shipping i live in california)
the main uses will be Editing with AAE, Premiere, and some gaming
I dont care if its intel or AMD
also will i be able to run most games on high? (Crysis, COD 4, L4D2, maybe a little SC2, games like that)
Resolution : 1920 x 1080
Also if they're any improvements i can make and stay in my price range please let me know what they are.
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
4000MHz
45 nm Deneb
4 x 512KB L2 Cache 6MB L...
$159.99
EVGA 768-P3-1362-AR GeForce GTX 460 (Fermi) Superclocked 768MB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
GeForce GTX 460 (Fermi) ...
768MB GDDR5
PCI Express 2.0 x16
was: $219.99
$199.99
$189.99 with Rebate
(^^ Would ATi be better? if so which card?)
ASUS M4A88TD-V EVO/USB3 AM3 AMD 880G SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
AM3
AMD 880G
4×240pin DDR3 2000(O.C.)...
$119.99
Corsair (XMS Series) CMX4GX3M2A1600C7: $104.99
2. Corsair CMPSU-750TX: $109.99
Combo Discount: -$30.00
Combo Price: $184.98
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
1TB
7200 RPM 32MB Cache
SATA 3.0Gb/s
was: $74.99
$59.99
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case ,comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
Steel ATX Mid Tower
USB / Audio / e-SATA Fro...
Support up to 5 Fans
was: $59.99
$49.99
LITE-ON 24X DVD Writer Black SATA Model iHAS-324-98
24X DVD+R 8X DVD+RW 8X ...
16X DVD-ROM 48X CD-ROM
2MB Cache
$19.99
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
Home Version
OEM
$99.99
is it any good?
Hmm by my count that would be $885 and since vid edit/premiere on the table
A case for GPU computing: Adobe Premiere Pro CS5 and the Mercury Playback Engine
http://tech.icrontic.com/articles/reviews/a-case-for-gpu-computing-adobe-premiere-pro-cs5-and-the-mercury-playback-engine/
So does this project suggest that Mercury Playback does not actually affect the performance of the editor? Not necessarily. This project consists of compressed 640×480 video footage. These small video files were being eaten alive by the massive 1090T hexa-core processor and 8GB of RAM. Premiere Pro CS5′s increased performance with multi-core systems coupled with bleeding fast hardware will make fast work of any simple projects such as this, not giving the GPU enough work to really make a difference. These results do suggest that if you’re editing small-time video footage, you will not benefit much from using Mercury Playback.
$679AR tower
$100 OS
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
CM GeminiIIS cooler $38 free ship
http://www.superbiiz.com/detail.php?name=FAN-PBU1&title=Cooler-Master-GeminII-S-RR-CCH-PBU1-GP-CPU-Fan-For-Intel-LGA1366-1156-775-AMD-AM3-AM2-AM2
Murissokah
1,256
134
I can second most of what batchuka suggested. The motherboard didn't really convince me though. The reviews for this motherboard actually look ok, but if it were my main build I would go with something a little more trustworthy, such as a GIGABYTE GA-890GPA-UD3H http://www.newegg.com/Product/Product.aspx?Item=N82E16813128435. An extra 65 bucks would upgrade your CPU to a 1090T for about 10~20% overall gain on CPU intensive tasks.
Since you asked, both your build and batchuka's will run most games on high @ 1900x1200. As for Crysis, the old VGA hog, just don't do AA nor max the shader settings and you should be ok.
HeyImGodly
368
17
thanks,
i adjusted my build with most of the things you included, but would this case work?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
also if i was to get the cpu cooler would I need thermal paste for it?
HeyImGodly
368
17
would this one work with my build?
theres also an MSI mobo I was looking at the runs about $109 with a combo and the one vv there is $108 with $15 instant
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128443
1. Unless someone finally posts a factual tabulated data of all mobo brands at the *same* pricepoint and % RMA when freshly bought, etc one should refrain from assuming brand X > Y because all/any mobo maker makes both gems/lemons at various price points. If one has no need for 8/8 CF any 890GX is a painful and useless top up
2. Also negative on premium paid for 1090T:
1055T + TA880GB+ with T-Series auto OC utility
http://translate.google.com.sg/translate?hl=en&sl=ko&u=http://whatnext.tistory.com/1100&ei=syizTKzrFZHKvQOTxMTMBg&sa=X&oi=translate&ct=result&resnum=9&ved=0CDYQ7gEwCDge&prev=/search%3Fq%3DTA880GB%252B%2Breview%26start%3D30%26hl%3Den%26sa%3DN
This was even on stock HSF + rudimentary value RAMs @@
Similar threads
