Hey guys, this is my first try at a custom PC build, it will be primarily used for gaming at 1080p single monitor and watching movies (and college I guess). Any advice or tips will be much appreciated. Would really like advice specifically on my selection of: Motherboard, Memory, SSD, Hard Drive, Case, and Power Supply, as these are the area's I'm least confident in my decisions. I plan to use the SSD for my operating system and don't plan to put any games on it (I've heard this is the thing). Planning on OC my GPU and CPU (and possibly system and vRAM cause I heard this was also a thing) but don't know much about it at this time so advice on that is also welcome. Do I need a sound card or Wired network adapter? What 22-24 cheap/good quality monitor would you recommend for gaming? This case front fan doesn't blow over the drives, is that a problem? Any recommendations on another case in the price range? Pretty much tell me any and every darn thing you can think of I need all the advice I can get. Thanks for reading
http://pcpartpicker.com/p/2JG8U
