Question Help a noob at Pc
Dec 4, 2023
40
So, I have this lenovo m900 SFF and I'm having an issue with finding the right sata power cable for it since it's a proprietary cable ( square 4 pin ) so I saw this particular one 8 pin dual sata cable. Is it safe to use this for my m900? or will this cause a problem?
No that's what you're looking for.
or
but I'd contact Moddiy support and see if that harness is compatible with your board.
Can you use the SATA 4 pin square power cable from the Lenovo m83 to the Lenovo M900 SFF?
SInce it's a proprietary cable it's quite hard for me to find ones just like it but I have these that work for the M83 so will this also work for my M900?
