L Leyha Commendable Feb 21, 2017 174 0 1,680 Mar 30, 2017 #1 I want to use ReadyBoost to my flash drive 16gb, my ask is if I set my flash drive is ReadyBoost, I can add more files to my flash drive? And what happens if the flash drive is freed from cpu
Solution Matt_150 Mar 30, 2017 I wouldnt bother unless you find that you are maxing out your 16GB and running out of virtual memory.
Matt_150 Respectable Dec 6, 2016 213 0 1,860 Mar 30, 2017 #2 How much Ram do you have? Readyboost will only make sense if you are low on RAM. Upvote 0 Downvote
Matt_150 Respectable Dec 6, 2016 213 0 1,860 Mar 30, 2017 Solution #4 I wouldnt bother unless you find that you are maxing out your 16GB and running out of virtual memory. Upvote 0 Downvote Solution
L Leyha Commendable Feb 21, 2017 174 0 1,680 Mar 30, 2017 #5 So I do not need this yes Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,612 22,159 184,590 Mar 30, 2017 #6 Leyha : So I do not need this yes Correct...you do not need this. Upvote 1 Downvote
