before i have rx 460sapphire 2gb, and i want to upgrade it to Zotac GTX 1050Ti (OC edition), and i have CPU FX-8370 with wraith, Do both cpu and VGA match, and will it later when i have replaced it there will be a problem?, like bottleneck
The GTX 1050ti is a good match with your current CPU. Although in some games that are CPU bound, you may experience some bottle-necking but nothing to severe. In order to minimize those moments you have to raise the in game graphic settings as much as you can in order to transfer the load back to the GPU. You can also try overclocking a bit your CPU. It will certainly increase your FPS output.
Finally I think that you should know that the GTX 1050ti is about 30% faster than your current GPU. I don't know if that number is enough for you to justify the extra expense. An RX470 may be a better purchase but you may also experience more bottle-necking issues with your current CPU.
