HELP about wi-fi settings
Leyha
Commendable
Feb 21, 2017
174
can someone help me?
i have wi-fi and it is connect about 6 user in my home so my problem is how to i manage this wifi speed, example 6 user connect to my wifi and 1 or 3 user use for download and streaming so 3 user other will be lag and slow internet sleed
so any solution please for manage wifi speed
Your first thing is to see if your router even has QoS settings.
There is quite a variation between routers on how you actually configure it. What you need to do is limit everyone else bandwidth so the internet connection never goes to 100%. You can not actually guarantee your bandwidth because the ISP is actually in control and you can do nothing if they drop your game data and send other data instead. So if you would limit all the other traffic to say 45 down and 20m up it would leave extra bandwidth for your games. Some routers you can attempt to put in minimum download/upload rates for your machine but it takes messing around with to get the setting correct.
Again it is not actually a wifi setting it is internet in...
It depends on your internet speed. In most cases it is your internet plan that you overload well before the wifi. There is very little you can actually do on the actual wifi. Most the issues with wifi are due to devices transmitting at the same time because they can not hear each other.
There are routers that can limit the internet usage with QoS but it does not work really well on smaller internet connections. Part of the problem is the rates are average rates and you get short burst of traffic.
Your first thing is to get a agreement between all users on how much each is to get. QoS is purely a electronic method of enforcing a agreement. In many cases you can get better results by setting options in the the download clients. This is especially true for torrent download. QoS does a very poor job of limiting torrents.
if i check my internet speed is
download 49,83 Mbps
upload 23,53 Mbps
i check alone test (only me in wifi) from speedtest.net
this sound is ridiclous but i want settings my wifi speed like you know like in internet cafe or public wifi example like restaurant or cafe
i test it from 1 cafe wifi and it is if i download i get very laggy but if i play like game onlline ex gta5/csgo i not get lag from internet and have normal ping,
i want make my wifi like this but i dont know how to do it
Again it is not actually a wifi setting it is internet in general. You can nothing if for example your neighbor is using his router on the same wifi channels as you. You are competing for the radio bandwidth and there is nothing you can do if you get lag because of this.
