(Help) Accidentally pushed in pins on CPU fan before applying to motherboard
marthswords
14
The title pretty much describes it. I bought a new motherboard and put the processor in. I then (heaven forbid) pushed the pins in on the CPU fan before putting it on the motherboard. Is there anyway to undo this with the intel pushpin CPU fans or am I screwed? Thanks :/
I'm not so sure I can. The pins are locked in place. I can't turn the screws or pull them back out. The black part of the pins are protruding from the clear plastic part of the pins so i don't know if they are pushed too far are not. Should I post a picture?
