hey, i just got some artic silver 2, and was careful to scrape off the old pink thermal tape before i applied it. but while applying the as2, i accidentally got some on the ceramic, so i first used dishwashing detergent like the instructions said to do. when that proved to be almost useless i used goo-gone which is also ok. i only used this on the ceramic, so on the core and hsf i used ispropyl alchohol. i thought i had cleaned it all off so i reapplied cleanly and set the hsf on top and clipped with no twisting. but now my computer wont even post to the BIOS.
It is overclocked but i never had ANY troubles before this and i didnt change ANY jumper or bios settings before doing this. I am 100% certain no artic silver touched any of the L1-7 bridges but i do know that some touched the little box looking things around the core. Could this render my cpu dead or does it just need more cleaning? Ive cleaned this sucker 3 times and still nothin, does anyone have a trick?
If I knew how to write, I would put a signature right here--->
