HELP! Blue screens after ugprading motherboard, ram & cpu :(
fattybobbyjones
36
Hi there. I just upgraded my old PC to a new Ryzen 2600 and Msi B450m Bazooka motherboard and adata xpg 8gb ram 3000mhz. I upgraded it from a gigabyte 970-a, fx 6300, and 8gb 1333mhz ddr3 ram. Every part is working because all the components showing up in the BIOS. I'm assuming it's a hardrive/windows problem. When it starts to boot to windows, it says comes up with that blue screen windows error, and restarts and proceeds to do the same thing. This is very frustrating because I spent a lot of money on this upgrade, does anyone know what went wrong? Thankyou!!
How would I go about doing this? Like I want to delete everything on my ssd but how do I access it if I can't even boot to it. Thanks for reply.
Build back old setup with motherboard, download windows iso, burn it to usb via rufus , build back new setup, then install new windows.
also backup your data, to somwhere, if its not big, use google drive,mega etc.
Documents, %appdata% , pictures etc.
The thing what you experience is because the original motherboard is connected to windows .
