Help - bottleneck question
Yeah . . . Dont worry! An i5 2500k is very powerful and can run a GTX 780 SLI perfectly. You dont even have to overclock.
well mine is clocked to about 4,3-4,5 ghz about there. so then i will thank you guys for the help :) i might buy a couple later this year so well thanks guys :)
If your CPU is OCed to 4.5GHz - Then it will handle a GTX 780ti with FLYING COLOURS! Dont forget to pick the Best Answer!
