[SOLVED] Help Building Budget Gaming PC
kingdonut239
59
I am trying to finish a build with a cheap price. Here are my current specs.
GT 730 (Upgrading to GTX 1050ti)
Intel i3 8100 3.6ghz
GIGABYTE H310M A
8gb ddr4
SEASONIC SS-350ET ACTIVE PFC
I need help looking for a decent pc case with glass side panel. I would like it to look appealing but with a cheap price, no more than $60. I also am not sure if I need a new power supply and if so, i need a budget power supply that will get the job done. I appreciate any and all help. I am also looking for parts specifically from amazon.
75w TDP GPU, 65W TDP CPU.
The SeaSonic unit could actually do it - although if you want to go with a side panel window etc, you might want something that looks a little better?
Do you actually want "glass" ie tempered glass? Or just a see-through side panel window?
Right now the 275R with TG is $45 after rebate and includes a bonus fan.
https://pcpartpicker.com/product/6bGxFT/corsair-carbide-series-275r-tempered-glass-newegg-edition-atx-mid-tower-case-cc-9011132-nwg
But it's $65 initially.
The Versa H18 TG is $50.
https://pcpartpicker.com/product/dgndnQ/thermaltake-versa-h18-tempered-glass-microatx-mini-tower-case-ca-1j4-00s1wn-01
If you just want a window, the Spec-05 is $30 after rebate...
https://pcpartpicker.com/product/qP8j4D/corsair-spec-05-atx-mid-tower-case-cc-9011138-ww
or the Q300L is $40.
https://pcpartpicker.com/product/rnGxFT/cooler-master-masterbox-q300l-microatx-mini-tower-case-mcb-q300l-kann-s00
As for a PSU, the CX450 is $23 after rebate.
Power Supply: Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply ($22.98 @ Newegg)
Total: $22.98
Generated by PCPartPicker 2018-11-27 15:43 EST-0500
It doesn't matter if it is tempered or not, I would just like to be able to see inside. I appreciate the help!
