So i'm gonna make a gaming computer myself for the first time and i already chose everything (parts) but i don't know if it will work or good or whatever so i need you to tell me if it will work fine or not. If something dosent match then tell me what to get.
Heres The Parts:
The Case:
Cooler Master HAF 912
Power Supply:
Corsair CX750
MotherBoard:
Asus ATX DDR3 1333 LGA 1150 Motherboard H87-PLUS
CPU:
Intel Core i5-4670K Quad-Core Desktop Processor 3.4 GHZ 6 MB Cache
GPU:
AMD Radeon R9 290 4GB
Memory:
Corsair Vengeance Blue 8 GB (2X4 GB)
Storage:
HDD:WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache
SSD:Samsung 840 Pro Series 2.5-Inch 128GB SATA 6Gbps Solid State Drive
Optical Drive:
LG Electronics 24X SATA Super-Multi DVD Internal Rewriter with M-Disc Support (Black)
Windows 8.1 Pro System Builder 64 bit
Uhhhh yeah.....
Btw what monitor should I get (I don't even have a monitor )
Not too expensive $100-200
Heres The Parts:
The Case:
Power Supply:
Corsair CX750
MotherBoard:
CPU:
GPU:
Memory:
Storage:
Optical Drive:
Uhhhh yeah.....
