Help building systems to play these.
steven37
287
Hi! I am building two computers for people and I am not the best at picking parts anymore lol. I asked them what they want to do with it they said game. and so I asked them to tell me a couple games they will be playing to get a better look at what type of specs they need in their systems.
System 1 is going to be playing League, Minecraft, and GTA V..
Game requirements:
http://tinyurl.com/nxyrk6y
http://tinyurl.com/qbqst4d
http://tinyurl.com/zaom6z9
For this system there isn't really a price range but I want it to be able to run the games at least on max settings for the cheapest price possible! thank you!
System 2 is going to be playing ESO, and Borderlands 2..
Game requirements:
http://tinyurl.com/zv6wxum
http://tinyurl.com/arnmlt7
For this one there is no need to add a video card because I already have one for it. Price I am aiming for is $500 Base price.
If you need anymore info please ask I want to make these computers perfect for their needs. I also want them both to have upgrade ability
These are my suggestions for what you ask. Maybe someone can find better deals or better systems, but that's what i would feel comfortable gaming with if i had that budget. I haven't included OS, peripherals or monitors.
For System 1:
PCPartPicker part list: http://pcpartpicker.com/list/6PRtnn
Price breakdown by merchant: http://pcpartpicker.com/list/6PRtnn/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($198.88 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.88 @ OutletPC)
Motherboard: Asus B150 PRO GAMING/AURA ATX LGA1151 Motherboard ($91.99 @ Newegg)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory ($77.99 @ Newegg)
Storage: Kingston SSDNow UV400 240GB 2.5" Solid State Drive ($59.99 @ Best Buy)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Video Card: Sapphire Radeon RX 480 8GB NITRO+ OC Video Card ($282.99 @ SuperBiiz)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case ($64.99 @ SuperBiiz)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply ($69.99 @ Newegg)
Total: $919.19
Generated by PCPartPicker 2016-09-02 14:50 EDT-0400
For System 2:
PCPartPicker part list: http://pcpartpicker.com/list/7fX78K
Price breakdown by merchant: http://pcpartpicker.com/list/7fX78K/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($110.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard ($63.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory ($38.88 @ OutletPC)
Video Card: Asus GeForce GTX 950 2GB Video Card ($133.98 @ Newegg)
Case: Thermaltake Versa H21 Window ATX Mid Tower Case ($43.99 @ SuperBiiz)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply ($36.99 @ Newegg)
Total: $476.30
Generated by PCPartPicker 2016-09-02 14:40 EDT-0400
Thank you so much for the reply! On System 1 is there anyway to get that cheaper? I'm not entirely sure she needs an ssd and 16gb of memory. It is her first computer after all. But I can still ask them about the price and see if its okay.. and for system 2 I think you accidentally missed where I said you don't need to add the video card. Could you help me get a better pc on that, I'm sure the parts can be a lot better without the the card taking up over $100 of the budget
Glad i helped you!
System 1
If she can afford it, is quite good. I found an SSD a "must" in PCs of that level. But you can save some money by removing it or choosing a cheaper one. The SSD won't give you higher fps, just better OS booting times and shorter loading times in the games you install on it. Not a necessity but something you will appreciate. If you take it away, you are saving 60$. If 860$ still to much, you can downgrade your GPU to a GTX960 2GB or a RX470 and swap the 2x8GB of RAM to 1x8GB of RAM (or 2x4GB and take advantage of the dual channel) so you same a couple bucks more. You will have something like this:
PCPartPicker part list: http://pcpartpicker.com/list/ZjxMbj
Price breakdown by merchant: http://pcpartpicker.com/list/ZjxMbj/by_merchant/
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory ($40.78 @ OutletPC)
Video Card: Asus GeForce GTX 960 4GB Video Card ($209.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($69.99 @ Newegg)
Total: $748.99
Generated by PCPartPicker 2016-09-02 19:54 EDT-0400
System 2
Yes! I have to confess that i totally forgot about that! Just take the GTX950 and use the 160$ that lefts to upgrade to an i5 and a better mobo. Get something like this:
PCPartPicker part list: http://pcpartpicker.com/list/kkB3yf
Price breakdown by merchant: http://pcpartpicker.com/list/kkB3yf/by_merchant/
Total: $481.12
Generated by PCPartPicker 2016-09-02 20:08 EDT-0400
Basically, are the same components that you have in the System 1 but with other PSU. You can even cut a bit more by choosing other case which basically depends on what you like.
I'll give this a try.
System 1:
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard ($69.89 @ OutletPC)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory ($32.27 @ NCIX US)
Storage: Sandisk X400 1TB 2.5" Solid State Drive ($247.07 @ Amazon)
Video Card: Gigabyte GeForce GTX 1060 6GB WINDFORCE OC 6G Video Card ($265.99 @ SuperBiiz)
Case: DIYPC F1-W ATX Mini Tower Case ($36.99 @ Newegg)
Power Supply: Rosewill 600W 80+ Gold Certified ATX Power Supply ($59.99 @ Newegg)
Total: $911.08
Generated by PCPartPicker 2016-09-02 22:13 EDT-0400
Or if that's too much, then:
Storage: Sandisk SSD PLUS 480GB 2.5" Solid State Drive ($112.99 @ Best Buy)
Video Card: Gigabyte Radeon RX 460 4GB WINDFORCE OC Video Card ($127.99 @ SuperBiiz)
Total: $639.00
Generated by PCPartPicker 2016-09-02 22:17 EDT-0400
System 2:
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard ($53.88 @ OutletPC)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory ($32.98 @ Newegg)
Storage: Sandisk X400 512GB 2.5" Solid State Drive ($134.99 @ Directron)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($51.89 @ OutletPC)
Total: $509.61
Generated by PCPartPicker 2016-09-02 22:09 EDT-0400
Hey! Thank you both for the replies! I've been working online changing and putting stuff together and talking to the owners and this is what I have so far... What do you think of these computers? and how do you think they will perform?
System 1
http://pcpartpicker.com/list/Wk74M8
The only thing I'm really worried about is the motherboard.. Do you guys think it will be okay in the long run?
System 2
http://pcpartpicker.com/list/ycvTnn
This one will probably have a gtx 770 in it..
