[SOLVED] Help checking my build changes.
kyrios
61
4
10,545
Hello!
I've decided to upgrade my pc, changing my MOBO, CPU, PSU and adding a new SSD.
here is the list of my final build:
https://pcpartpicker.com/list/xDDKy4
I believe everything should compatible since the website is not throwing any warning, but the www.userbenchmark.com said something like my ram is not compatible but when checking the gigabyte compatibility list, says that the corsair vengeance LPX 2400 it is in fact compatible. Here is the link of the MOBO support section: https://www.gigabyte.com/Motherboard/Z590-GAMING-X-rev-1x/support#support-doc
Also, the list of Storage compatibility only shows the Samsung 980 nvme Pro, but I cant find the 980 nvme (non pro) anywhere, soo I'm a little concern since m.2 can be tricky when compatibility speaking sometimes.
And finaly... I am asuming that this MOBO Gigabyte Z590 Gaming X have the TPM2.0 for windows 11, but I'm not entirely sure since I haven't found any document that can prove it.
Got to mention, that as MOBO alternative I have the Gigabyte z590 UD.
I will appreciate a lot if anyone gives me a second opinion, and thanks in advance.
Well, just gonna have to work with what's available to you then.
So everything's as is in your partpicker list, save for MOBO, CPU, PSU and adding a new SSD?
That cooler is too weak. You can run that cpu with it with some lower power limits in place, but the performance will be less than ideal.
That psu is lit - literally and figuratively. You might get lucky and get one that doesn't pop, but do you really want to take a chance with that?
Those 2 are about the only flags here.
Does the store not carry Samsung 970 Evos? Those are still good.
That ram is really too slow. You can get a proper 3200mhz 2x8gb kit, for less than those two single sticks. That cooler will probably struggle with that CPU. The 11700k is a very hot CPU. I would recommend going with a 5800x, over it.
PCPartPicker Part List
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor ($374.99 @ Newegg)
CPU Cooler: Cooler Master Hyper H412R 34.1 CFM CPU Cooler ($29.99 @ Amazon)
Motherboard: Gigabyte B550 AORUS ELITE V2 ATX AM4 Motherboard ($176.50 @ Amazon)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($50.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500 GB 2.5" Solid State Drive
Storage: Western Digital WD_BLACK SN750 SE 500 GB M.2-2280 NVME Solid State Drive ($54.99 @ Amazon)
Storage: Toshiba Product Series😀T01ACA 2 TB 3.5" 7200RPM Internal Hard Drive ($99.00 @ Amazon)
Video Card: Asus GeForce RTX 2060 6 GB DUAL OC Video Card ($725.00 @ Amazon)
Case: NZXT Phantom 530 ATX Full Tower Case
Power Supply: Gigabyte P GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($109.99 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($108.78 @ Other World Computing)
Monitor: Samsung UR59C 32.0" 3840x2160 60 Hz Monitor ($399.99 @ Amazon)
Total: $2130.22
Generated by PCPartPicker 2021-11-12 10:55 EST-0500
Alder Lake is another consideration, given that you want win 11. I simply see 0 reason to go with an 10th or 11th gen i7, when the 12600k is superior, in pretty much every benchmark, and is the same price, if not cheaper. I had to change the cooler, but it is possible Cooler Master will have an LGA 1700 bracket for what you have, but the Noctua is better.
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor ($299.99 @ B&H)
CPU Cooler: Noctua NH-U12S redux 70.75 CFM CPU Cooler ($49.95 @ Amazon)
Motherboard: Gigabyte Z690 UD DDR4 ATX LGA1700 Motherboard ($219.99 @ B&H)
Total: $2118.67
Generated by PCPartPicker 2021-11-12 10:57 EST-0500
Reactions: rgd1101
Total: $2130.22
Total: $2118.67
Those are very good options, but I'm stuck with i7 11700kf, cuz is the only option aside from a i3 CPU that my components provider have at the moment, and can't really buy online since I depend on a specific payment option that I'm getting from that provider. Aaaand I live out of USA, so I really don't have many alternatives.
OMG! I think you just saved me then... cuz I'm not feeling any lucky, I might get a faulty one >-<
what do you think about this PSU? Corsair RM 650
https://www.amazon.com/-/es/Corsair-Watt-Gold-alimentación-completamente/dp/B07RFZPN8G/ref=sr_1_1?__mk_es_US=ÅMÅŽÕÑ&crid=27IKFSKF7CI6Z&keywords=corsair+rm+2019+650w&qid=1636740635&s=electronics&sprefix=Corsair+RM+(2019),electronics,238&sr=1-1
about the ssd they only have the samsung 980 nvme 500gb and 250gb
ooh and the fan, this is what I found that could help with performance that doesn't destroy my wallet.
https://www.amazon.com/Original-Design-Towers-Cooler-SCFM-2000/dp/B07QMK5R45
RM 650 is good. BUT, if you plan on replacing the current card later on with something like a 3080, it won't be enough.
THAT is unfortunate...
yeaah the Covid killed all supplies in my country,
Honestly, by the time I get to be able to buy a possible 4080, I would definitely buy a complete new PC, cuz I really cant pay for it atm... which now makes me think that might be better with the Gigabyte Z590 UD istead of the Gaming X motherboard
Motherboard is the most complex part of a PC build to choose from.
If you don't know exactly what you want out of one... you might not miss anything going with the cheaper of those 2 boards.
XD yeah, i went for the Gamin X because is 40bucks more only... like I might get a better product maybe if I pay that extra
