help choose 50$ headset
Leyha
Commendable
Feb 21, 2017
174
before i have headset and it is very uncomfortable hurts my ear (cuz it is cheap headset rexus f22), i use headset for long time like 18hours/day, and im looking for headset under 50$ better i buy Logitech G231 or corsair HS50 and steelseries siberia 150, or any recommend please?
thanks you for reading and helping me
Another amazing option is the HyperX Cloud Stinger.
https://www.amazon.com/HyperX-Stinger-Nintendo-HX-HSCS-BK-NA/dp/B01L2ZRYVE/ref=sr_1_3?s=electronics&ie=UTF8&qid=1523330214&sr=1-3&keywords=cloud+stinger
It also depends on what you have more of a preference towards. Better sound or mic quality. The sound quality of the Siberia 150 is pretty hard to beat at that price point, but the mic quality on the cloud stinger is definitely better than the others. It also comes down to comfort. I can personally speak as a Siberia 150 owner that it is very comfortable and I can wear it for long periods. I can't speak for the others though, but i'm sure they are fine.
