Hello everyone I need some help choosing some fans for my pc case phanteks xt pro ultra I'm looking for some ripoffs fans of lian li basically cheaper fans, I found this ones on Amazon TZMRIT white unifans 120mm and jungle Leopard splicing V2 and was wondering if anyone knew about this fans, reviews says they're quite good compared to the lian li but its better asking before xD, i currently have the 4x140mm phanteks fans that comes with the case, a 360 AIO thermalright frozen prism 360 and 3x120mm deepcool FC120 fans, my idea was to change the AIO, bottom 3 and the rear exhaust fans keeping the front ones since theyre not really visible.
This are the fans i have found https://www.amazon.it/TZMRIT-UNI-FAN-White-Infinity/dp/B0CGHZ9R64/ref=sr_1_5?__mk_it_IT=ÅMÅŽÕÑ&crid=3JRA5U3RV75DE&dib=eyJ2IjoiMSJ9.0oxb7MbkK0qrJ9Lo1qusaL7s41wd7aQ9hK4T9UEJnsIy-glliku1rTdnqEvwht9gze1GTh5qc3jJp75wwBVsTmcqVld3ikR8ucgW8ogXo0y58VmzyxKIrOIcxfMialr-FP106dsKwfYCiIjI3buH2T8FmPfk-STDeHBi1L9DGpO5D9VYmDsEIn_VWvkfxjuD_jhYhNqPmbNbWUBkZbglOVUQU0Nl15v-bkp96NylwjiBku-zGOe7fXCCK7i1qUY6ofh7YlniU345hxQxeZhoN6eAR8y0CpCrHPZn_RlwciA.cjqEKF5Kcd2a-UIlP8-1_b7Zg3GzgKWw6Hif-cVScG0&dib_tag=se&keywords=ventole+pc+uni&qid=1728390322&sprefix=ventole+pc+uni%2Caps%2C77&sr=8-5
https://www.amazon.it/Jungle-Leopard-Splicing-BK-V2RS/dp/B0D6G6JRTX/ref=sr_1_55?__mk_it_IT=ÅMÅŽÕÑ&crid=3JRA5U3RV75DE&dib=eyJ2IjoiMSJ9.0oxb7MbkK0qrJ9Lo1qusaL7s41wd7aQ9hK4T9UEJnsIy-glliku1rTdnqEvwht9gze1GTh5qc3jJp75wwBVsTmcqVld3ikR8ucgW8ogXo0y58VmzyxKIrOIcxfMialr-FP106dsKwfYCiIjI3buH2T8FmPfk-STDeHBi1L9DGpO5D9VYmDsEIn_VWvkfxjuD_jhYhNqPmbNbWUBkZbglOVUQU0Nl15v-bkp96NylwjiBku-zGOe7fXCCK7i1qUY6ofh7YlniU345hxQxeZhoN6eAR8y0CpCrHPZn_RlwciA.cjqEKF5Kcd2a-UIlP8-1_b7Zg3GzgKWw6Hif-cVScG0&dib_tag=se&keywords=ventole%2Bpc%2Buni&qid=1728390322&sprefix=ventole%2Bpc%2Buni%2Caps%2C77&sr=8-55&th=1
