Help choosing a good compatible Heatsink fan for old computer please.
Ted99
9
Hi could you please help me choosing a good heatsink fan compatible with my old computer. Thanks.
Here are my specs:
CPU Type: DualCore Intel Core 2 Duo E4400, 2000 MHz (10 x 200) [Conroe-2M]
Motherboard Name: Unknown
Motherboard Chipset: Intel Bearlake G33
Video Adapter: Intel G31/G33 Chipset - Integrated Graphics 0 [A-2] [8086
29C2] [17AA 302E]
CPUID CPU Name: Intel(R) Core(TM)2 CPU 4400 @ 2.00GHz
Operating System: Microsoft Windows 7 Home Premium 6.1.7601.18247 (32-bit)
PCI Devices: 8086-29C0 8086-29C1 8086-29C2 8086-29C4 8086-294C 8086-2937
8086-2938 8086-293C 8086-293E 8086-2934 8086-2935 8086-2936 8086-2939
8086-293A 8086-244E 8086-2916 8086-2920 8086-2930 8086-2926 8086-2932
USB Devices: 04B3=310C 045E=00B0 0BDA=0111 045E=00B0 045E=00B0
DMI MB Manufacturer: LENOVO
DMI MB Product: To be filled by O.E.M.
DMI MB Version: To be filled by O.E.M.
DMI SYS Manufacturer: LENOVO
DMI SYS Product: 96892AG
DMI SYS Version: LENOVO 3000
DMI BIOS Version: 2SKt46A
[[[ Unknown Items ]]]
Motherboard,64-0103-000003-00101111-011909-Bearlake$2SKT46AG_08.00.15.2SKT46
A.2009.0119.001041
Motherboard,DMIMOBO: LENOVO To be filled by O.E.M.
Motherboard,DMISYS: LENOVO 96892AG
For an old Core2 I'd go with something like this. I used the version 1 for my Core2 E6400 way back and it worked great. It clips into the mount holes from the front so you don't mess with a backplate. It's pretty cheap on Newegg. Probably overkill for stock speeds, but you can always look at the cheaper standard style AC coolers. They always work great. If you have a slim style case you may want to look at the smaller coolers.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Cheers. That seems perfect.
