[SOLVED] Help choosing a monitor with required specs
Tapi
Commendable
Oct 29, 2019
4
I would like to ask for advice:
I am looking for the an LCD 32" (31,5") QHD (2560 x 1440) 16:9
With these specs:
  • min 120 Hz
  • max 4 ms response time
  • G-SYNC or G-SYNC compatible FreeSync
  • VA or IPS (think IPS would be better)
  • adjustable height
  • price max cca 1000$
My preliminary choices are:
  • LG 32GK850G see here or
  • Acer Predator Gaming Z321QU bmiphzx see here or
  • Samsung C32HG70 see here (but not sure if it is G-sync compatible)
Any suggestions, comments or tips welcomed, THX.
THX very much for your answer. I guess you mean this one: MSI Optix MAG322CQRV
Unfortunately, it is not in the list of MSI G-sync compatible LCD (1/2019): Here
(but the list is not very new so maybe this one is compatible because similar MAG271CQR can run G-sync unofficially)
Hi @Tapi
Yep, that the one. Please note the below area in red. Direct copy & paste from the link. Not sure if it matters, but I am currently using this monitor with a 1060 6GB and in my humble opinion, it looks great. I play most everything at 1080p due to my 1060's limited abilities beyond that resolution, but I have cranked the settings up to 1440p in several games and I "Oooh'ed & ahhh'ed" a time or two. :)
"MSI Optix...
With these specs:
  • min 120 Hz
  • adjustable height
The above monitors are all nice. About 2 months ago I bought this MSI monitor, and so far, I absolutely love it.
At a glance:
Curved 32"
Freesync
1440p @ 144hz
1ms
VA panel
At a glance:
Curved 32"
Freesync
1440p @ 144hz
1ms
VA panel
Hi @Tapi
"MSI Optix MAG322CQRV Curved Gaming Monitor 31.5 Inch, WQHD, VA, 144 Hz, 1 ms, 2560 x 1440, 1440 p, 1500R, RGB Mystic Light, Display Port, 2 x HDMI, USB, AMD FreeSync, G-Sync Compatible"
