Help Choosing a Video Card.
doje1999
130
Hey guys, need some help picking out a video card. These are my current specs.
cpu: Intel e5200 @ 2.5
mobo: Gigabyte GA-G31M-ES2L
memory: G.skill 4 GB DDR2 800 mhz
case: Antec 300
psu: Corsair CMPSU-400CX 400W
os: Windows XP Service Pack 2
I'm looking to spend under $100 and heard the 4830 would be my best buy. I wanted to know if there is a drastic improvement for the 4850 that it'd be worth spending another $50 on it. Or maybe a GTS 250. Also, I'm looking to OC to about 3.2-3.5 and was wondering what cpu cooler would be good with my current setup. Any advice would be much appreciated. Thanks.
Really? I looked at the customer reviews on this psu on newegg, and many of them are running SLI and Crossfire on it...And I'm sure I saw builds with GTS series and 4850 powered by this psu.
I see, well looks like I'll just pick up the sapphire 4830. Can you recommend a good cpu cooler for my rig?
Not too sure what 400cx is? Is that your recommendation for my cpu cooler? Do you think the psu can handle 4830x2? Thanks.
400cx is the corsair 400w.
idk why they cant just put 400w its always cx or vx or tx, hx on and on.
You have a big enough case for a s1283 xigmatek + arctic silver 5 compound
Thx! What does the arctic silver 5 compound do?
Arctic Silver 5 is thermal compound that goes inbetween the Heatsink and CPU.
It's a heat spreader to cool temperature's.
If you decide to Overclock, this is recommended usage of any tower.
The stock cooler that comes with the cpu should be good enough for a low/mid Overclock.
