Help choosing budget gaming motherboard for Skylake build
Russsel_Leonard
Commendable
Nov 24, 2016
29
Hi Guys! So I want to build a rig and I want to build a Skylake build. What is the best BUDGET motherboard for i3 then I will later upgrade for i7. I prefer motherboard that can oc cpu. Any suggestion guys? Thanks in advance!
Out of those two, I'd choose the z170m Plus as it has extra SATA ports, but at the expense of pci x1 slots. It depends which you'd rather, but they are v similar. The z170e and z170a are slightly better if you want more features though.
Ok! Thank you so much! :)
