Hey, I've just joined to get help with my first build and could use some assistance with cooling; I was hoping I could get some opinions on some good options with varying price ranges, I need a CPU cooler and also other cooling mechanisms around the case.
Here's the build so far:
CPU - Intel Core i7-4790K (Plan to overclock)
GPU - MSI GeForce GTX 980 Ti (Coming out on the 22nd)
RAM - G.Skill Trident X Series 16GB (2 x 8GB) DDR3-2133 Memory
Motherboard - Asus Z97-A ATX LGA1150
Case - NZXT Phantom 530
Specifications for where the case can hold fans and at which dimensions:
Front 2x140mm/120mm or 1x200mm
Rear 1x140mm/120mm
Bottom 2x120mm
Side 1x140mm
Top 2x200mm/140mm or 3x120mm
Interior 1x120mm/140mm
Opinions on other parts of the build is also welcome. 😉
Rear 1x140mm/120mm
Bottom 2x120mm
Side 1x140mm
