Question Help Choosing Motherboard!
Gtlogic10
4
Hi All,
I have a Q9650 processor which I would like to overclock to use it for playing compatible games and image/video editing.
The available motherboards around are Gigabyte GA-EG41MT-ES2L, Gigabyte GA-G41MT-S2P and Asus P5G41T-M LX.
Kindly provide the differences and help in choosing amongst the three G41 chipset motherboards as to which is better for overclocking and overall performance.
Thanks & Regards :)
Of the three you listed, I would go with the GA-G41MT-S2P. Higher phase count - geared more for OCing.
Note that I would never put money into buying tech this old. You probably won't get any kind of warranty and parts will most likely be used.
Reactions: Gtlogic10
Gtlogic10
4
Thanks for the suggestion. This isn't my main PC , it is old tech and the refurbished mobo doesn't cost much after all. I'll be upgrading to more up-to-date tech, just awaiting the prices of components to go down somewhat.
