Question Help Choosing PC Parts 2000€ EU
cutiegardevoir
6
Approximate Purchase Date: In the next ~14 days
Budget Range: 1850-2000 € before shipping (best if fully used because I want it to last a long while)
System Usage from Most to Least Important: Gaming (specifically simulation-type games, but sometimes play other games)
Are you buying a monitor: No
Do you need to buy OS: No, will use Linux (with maybe dual-boot Windows, but I'll decide on that later)
Preferred Website(s) for Parts: amazon.de (or other shops that deliver in Europe) also while my country usually has prices much higher than just buying from amazon this site can show prices of that specific part in each shop: https://www.kainos.lt/
Your Monitor Resolution: 3840 x 1200 (it can be separated into two screens)
Parts Preferences: AMD x3d cpu since it's useful for simulation games
Additional Comments: Do not care about the looks as long as it is functional and need a motherboard that has a good wifi board (or a separate adapter for wifi because I do not have ethernet). Moving from laptop to PC so I do not have good knowledge of computer parts (but I do know how to assemble a PC since I've done it before).
I did this all in PCPP, because it's easy for me to use.
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor (€383.99 @ Mindfactory)
CPU Cooler: Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler (€66.89 @ Alternate)
Motherboard: ASRock B650E PG RIPTIDE WIFI ATX AM5 Motherboard (€247.04 @ Galaxus)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (€121.18 @ Galaxus)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€135.83 @ Galaxus)
Video Card: XFX Speedster MERC 310 Radeon RX 7900 XT 20 GB Video Card (€799.90 @ Alza)
Case: Deepcool MATREXX 55 MESH ADD-RGB 4F ATX Mid Tower Case (€73.81 @ Amazon Deutschland)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply (€107.99 @ Mindfactory)
Total: €1936.63
Generated by PCPartPicker 2023-12-27 21:48 CET+0100
Total: €1936.63
If i switched the GPU to 7800 XT would it be fine?
