Help compare CPUs
So do I pick the laptop with an A6-9220 cpu or the PentiumN3710? Same price, the only other difference is the A6 has 8gb ram and the pentium has 4gb ram. Casual gaming and internet usage will be it
the A6 has 2 cores , the intel has 4. A6 has 8gb of ram , intel has 4 (you can upgrade), A6 has better graphics performance vs intel (you dont need alot you are playing a 2d game).
i would consider you check 2 sites :
http://www.cpu-world.com/Compare/285/AMD_A6-Series_for_Notebooks_A6-9220_vs_Intel_Mobile_Pentium_N3710.html
http://cpu.userbenchmark.com/Compare/Intel-Pentium-N3710-vs-AMD-A6-9220-APU-2016-MSR/m141841vsm300155
After reading and comparing both, it all comes down to a personal choice and budget.
Yeah I basically play one steam game called prison architect, nothing crazy like skyrim
