I built a system for my nephew and I can't find which RAM would be compatible with the CPU(Core2 DUO E6600) and the Mboard(P45TS). I've tried some different sticks but i'm not sure which one is not allowing the system to boot. It booted on an old 2g stick of DDR2 800. Id like to get the fastest DDR3 that the MB and CPU will both support. Thanks for any advice you can give...!
MOTHERBOARD
http://www.asrock.com/mb/Intel/P45TS/?cat=Manual
PROCESSOR
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115003
MOTHERBOARD
PROCESSOR
