[Help] Computer Freezing and Not Responding to Power and Reset Switches
Mar 25, 2018
6
I recently built my pc and I had received all my parts except for my ram at the time so I borrowed some ram from my friend and my pc ran without any issues. What he had was a single 4gb stick of hynix ddr4 memory clocked at 2133 mHz I believe. After my ram did come in (this kit https://www.newegg.ca/Product/Product.aspx?Item=N82E16820158605&cm_re=geil_super_luce-_-20-158-605-_-Product ) I swapped the sticks and booted my pc on. My pc booted and everything was normal until I went to install the software to control the lights (asus aura) when I downloaded it and installed it, I worked around with the lights and after a few minutes of tinkering within the software, my pc crashed with the monitor not displaying anything and the pc still running (all the fans were still spinning and the leds on the ram and motherboard were still lit up). What I noticed was that when I tried to press the reset and power switch, was that nothing would happen, my pc would not respond. When I did get my pc back up (restarting it through shutting off the power supply) I uninstalled the asus aura software, thinking that it probably was the reason why my pc crashed in the first place, that didn't help. I've also noticed that the timings for the ram while using it is 15-15-15-36 when the kit is supposed to run at 16-16-16-36 and whenever I try to bump up the frequency to 2400MHz which is what it's supposed to run at, it refuses to boot into windows so I'm stuck with my ram running at 2133MHz. To this day, my computer still randomly crashes at times and will not respond to the reset/power switches. Is it possible that my ram is faulty or it's just not compatible with my motherboard?
My specs:
Ryzen 5 1600 (stock clock)
Asus Strix B350-F motherboard
Evga gtx 1060 3gb SSC
16gb Geil super luce ram ( https://www.newegg.ca/Product/Product.aspx?Item=N82E16820158605&cm_re=geil_super_luce-_-20-158-605-_-Product )
Evga 450bt power supply
Fractal design meshify c case
I don't believe I have fried any of my components, everything works fine most of the time but it crashes here and there at random times
I don't think I will be able to borrow ram from my friend anytime soon, I checked up on my motherboard's memory qvl and my memory kit is not on there, can't memory kits still function on the motherboard even if it's not on the qvl?
I did some research and this trident z rgb kit ( https://www.newegg.ca/Product/Product.aspx?Item=N82E16820232634&cm_re=trident_z_rgb_amd-_-20-232-634-_-Product ) is supposed to work for my cpu and motherboard as advertised on their website https://www.gskill.com/en/product/f4-2400c15d-16gtzrx ( this same kit appeared under the list of verified working kits for my motherboard on their website ). When I go on my motherboard's qvl list though, I cannot find the same kit. Is it wise for me to purchase this kit?
