Help! Computer keeps restarting.
technosapien330
5
So I just built a new pc a month ago, worked great until this morning. it keeps restarting randomly. sometimes 5 mins apart, sometimes 2 hours apart. I've checked the mobo voltages and temps everything seems normal. please help me think of new things to check!
Hi there technosapien330,
What are the specs of the system?
I guess you can try several things:
- In case you have more than one RAM stick, you can use only one at a time(on different slots). There restarts could be caused by faulty RAM.
- Update your GPU drivers. In case you have both integrated graphics as well as additional GPU, you can take that out of the system and see whether the issue persists.
- Perform some stress testing. In case the system reboots, then I guess this could point towards a PSU related problem. Unfortunately, the easiest way to see whether this is the case is to just borrow one from somebody and install it in your system.
Cheers,
D_Know_WD
