A while ago my PC stopped working. When the tower was turned on, the fans turned on, but eventually turned off. Nothing booted up, just the fans started spinning, but the monitor said signal missing. The only way to turn it off was to hold the power button, or unplug it completely. I believed the issue was the motherboard, so recently, I bought a new motherboard, the exact same motherboard as before. I went through and plugged everything in that needed to be plugged in (I'm pretty sure), but the same issue happened that did in the past. I don't know what the issue could be. The Cooler Master case has a red light when power is given to the case. I will bring it to a local PC shop, and hopefully they can diagnose and fix it.
