Help, confused between a G2460PF, XG2401 or a XL2411?
Jun 27, 2018
Im currently looking for a 24", 144hz monitor, which in those 3 monitor would you recommend the most? Planning to get a GTX 1060 GPU. If you can recommend me other "bang for buck" monitor for that catergory, that would be great.
Considering how there are people who come from all over the world, where are you located and what currency are we dealing with? On another note, are all three monitors priced the same, where you're purchasing from?
If they're the same all round, I'd pick the Zowie monitor.
Moved thread to Display section
Lutfij
