[SOLVED] Help - Connecting RX 570 to "VGA only" Samsung monitor.
tar3k10
12
So i just got an RX 570, it has DVI-D, Display Port and HDMI Port.
And my old Samsung monitor only has VGA.
At first i got this DVI-D to VGA converter
It didn't work at all not even one.
Then i got a Display port to VGA
At first it worked for a day (Screen flickering to black now and then), then it went dead and no display as well.
What type of converter should i get to work fine? (Aside from getting a new monitor, no budget for a decent one ATM)
That's perfect.
I have been using the same adapter for more than 2 years and i have had no problem.
In fact, this is the best HDMI to VGA adapter you can buy.
You get what you pay for.
The white adapter in the image is a DVI-I adapter.
It will not work.
You need an HDMI / DP to VGA adapter.
1-I believe that's DVI-D (Single Link) but yea the one i have is dual link, so I'll just update the picture.
2- I tried both and didn't work, i believe i need a specific type to work then but i'm not sure which.
That's perfect.
Are u referring to the one i posted or the one you posted?
I hope u r talking about the one i posted because it's in a store nearby.
Thanks for all the help. 😍
