I just finished a build with a Corsair 4000D Airflow case ( MSI Z490-a pro mother board). The manual for the case shows seven wires coming out of the front panel. USB 3.0, USB 3.1C, HD Audio, Power Switch, Reset Switch, Power(+,-) and HDD(+,-). There aren't seven wires coming out of the front panel, there are six. USB 3.0, USB 3.1C, HD Audio, and labeled leads Power Switch, Reset Switch, and HDD(+,-). The HDD(+,-) lead is tabled wrong. When its hooked up to the HDD pins on the mother board, the power switch shows hard drive activity and stays off with no activity. When the wire labeled HDD(+,-) is hooked up to the Power(+,-) pins, it shows when the power is on and blinks when the computer is asleep. Obviously its just labeled wrong. But what do I do for an HDD light? The only two options left are the PowerSw wire or the ResetSw wire. I'm a little concerned about moving those onto the HDD(+,-) pins because they are supposed to be quick jumpers, not always on or working. Any help would be appreciated. I can live without an HHD light, but for $100 and only one USB 3.0 port on the front panel, I want that HDD light ![Smile :) :)](/data/assets/smilies/smile.gif)
