[SOLVED] Help converting current build into a custom loop PC
tots4life16
48
7
10,535
Budget (including currency): $1000
Country: US
Games, programs or workloads that it will be used for: Mining / Gaming
Other details:
My Current Rig is as follows.
PCPartPicker Part List: https://pcpartpicker.com/list/9s7nVc
CPU: Intel Core i7-10700F 2.9 GHz 8-Core Processor ($263.99 @ Newegg)
CPU Cooler: NZXT Kraken X63 98.17 CFM Liquid CPU Cooler ($149.99 @ Adorama)
Motherboard: ASRock B560 Steel Legend ATX LGA1200 Motherboard
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($112.99 @ Amazon)
Storage: Mushkin Pilot-E 1 TB M.2-2280 NVME Solid State Drive ($114.99 @ Amazon)
Storage: Seagate BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive ($45.95 @ Walmart)
Video Card: EVGA GeForce RTX 3090 24 GB FTW3 ULTRA GAMING Video Card ($3499.99 @ Monoprice)
Case: NZXT S340 ATX Mid Tower Case
Power Supply: Asus ROG STRIX G 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Total: $4187.90
Generated by PCPartPicker 2021-05-02 00:14 EDT-0400
I was thinking of upgrading to the Lian Li 011D case as I heard that that was a good case for watercooling. I want to go with soft tubing as well since this would be my first time building a custom loop and would think it would make the whole process a lot easier. I want to watercool my gpu as well as my CPU. I’m hoping EKWB releases the active cooling backplate soon for my model gpu but I think in the mean time I’d be more than fine to just go with their front plate and then upgrade to the active cooling backplate down the line. I would really appreciate any help getting a list of parts together to convert my rig to water cooling thanks!
The case you currently have can accommodate a custom loop, only thing is that you will need to be choosy in what parts to pick and drop into the case. The S340 can have a single 120mm rad at the rear, then have a 240mm radiator(or a 280, if you have the revised S340 design) to give you a 360mm loadout. You will also need to read through the watercooling sticky(in my sig space) first since the loop will have to be setup and maintained by you.
Preferred sites for purchase? There are a number to choose from.
