I've moved into a fairly newly-built home and there are phone jacks everywhere (6 to be exact) and they're all using cat5e cables.
My plan, after reading many threads online, is to convert them all to ethernet cables for gigabit internet.
So here's what I found:
* communication box outside, ATT fiber > keystone > cable that goes into the house
* wiring closet, inline cable > keystone > cable that goes into the ATT modem (ONT port)
* living room is the only place that had a RJ45 jack in the wall. Noticed keystone and cable are both T568A
Important Note: I opened up every phone jack in the house and they each have just the "blue" pair of wires connected to the keystone. There is only one cat5e cable behind each wall plate.
So the fun begins.
I replace my bedroom's phone jack with a RJ45 keystone, find the corresponding cable in the wiring closet with a toner, terminate the end with another keystone, plug in a cat5e, then plug it into the modem. Nothing, not even "connected, no internet".
Grabbed a network tester, connected it to my bedroom RJ45, and only getting link lights 4+5 (the blue pair). Weird.
Tried different cat5e cables, cat6 cable, re-terminating with new keystones, changing both ends from T568B to T568A wiring... still only getting the same 4+5 link lights. What.
I posted this on reddit and a guy keeps saying that I'm daisy-chained somewhere but I've checked every inch of this house... inside and outside, opened up every box hung up on a wall, and I've reached my limit.
I don't normally ask for help but I've run out of ideas..... please help!
So the fun begins.
