Hi there
I recently moved from my house and I packed down my PC for a month or so.
The PC, i put in the box, my cabin came in when I bought it from new.
So the PC has been with the front up in the air for a month or so, not orientated like it would normally.
In my new place I booted up my PC, and the idle temps on my PC was really high.
I took of my AIO Kraken X62 pump and radiator and gave it a good shake, because I read that after the pump has been standing still for a while there could be bubbles in the tubes.
That made the idle temps go down to 30 degrees, which I guess is okay.
Now when I run Cinebench 15R15 my temps rockets in to the air.
Below is all max temps achieved under 100% load in Cinebench
Core 0: 95
Core 1: 100
Core 2: 88
Core 3: 100
Core 4: 73
Core 5: 84
I have taken off the AIO and put new paste on several times but no changes.
So today, I bought a new AIO, because I thought that it might actually be broken, so I bought the KrakenX63
Only to discover the same temps.
My CPU is delid and have been OC to 4700MHz, with no problems at all - before moving.
Now on BIOS default it goes 3700mhz, but the temps still goes like above and its thermo throttling and 3700MHz goes to 2600MHz.
The AIO goes with full RPM and the same goes for all the fans.
I have eliminated that the cooling should be a problem - or have I?
Is the CPU toasted, and did it toast when I started the PC up after moving, with the high idle temps?
I am really confused and frustrated about it, what has happen since I moved.
I really hope somebody out there has the right answers.
Greetings from Copenhagen - Denmark (That´s why my English is not the best)
Allan
This is my specs:
Intel Core i7 8700K
ROG STRIX Z370-F GAMING
DDR4 16 GBytes RAM G.Skill
Asus GTX1080
AIO NZXT Kraken X63 280mm
Core 0: 95
Core 1: 100
Core 2: 88
Core 3: 100
Core 4: 73
Core 5: 84
Allan
This is my specs:
Intel Core i7 8700K
Asus GTX1080
