Help cutting costs/improving parts in a beginner PC
rocketship92
4
I have been thinking of getting a gaming pc for a while now and I want to play games along the lines of Skyrim/BF3 etc. Hence I've been looking at a building a PC capable of playing these but with some future proofing which will cover me for new games over the course of the next 2/3 years if possible. I will be playing a max resolution of 1080p (on my bedroom TV) and would like a frame rate of 45+ for the games mentioned. I doubt I will be overclocking. My budget is £500 but pushing the price closer to £450 is more than welcome. I have been reading up on gaming PCs recently outside of work (which has resulted in a few late nights) and have come up with the following combination (Note: did not use PC parts picker as it often listed greater prices than I could find elsewhere). Is this a good combination or can I cut costs by using cheaper parts more suited to my purpose?
CPU: Intel i-5 4590 3.3GHz Quad Core (£117.77 @ Newegg)
Motherboard: MSI B85M-P33 Intel B85 (Socket 1150) Motherboard (£34.99 @ Novatech)
Memory: Team Vulcan 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) (£38.27 @ Newegg)
Storage: Seagate Barracuda 1TB 7200 RPM 64MB Cache SATA (£41.22 @ Newegg)
Video Card: MSI Radeon R9 270 TWIN FROZR GAMING OC 2GB GDDR5 (£132.98 @ Novatech)
Case: Zalman z9 PLUS (£44.00 @ Amazon)
Power Supply: RAIDMAX Cobra RX-600AF-B 600W ATX 12V v2.3/EPS 12V 80 PLUS BRONZE (£38.27 @ Newegg)
Optical: Samsung 224DB 24x DVD Re-Writer - SATA - Black - OEM (£12.98 @ Novatech)
OS: Windows 7 PRO (£39.99 @ Mr High Tech)
The total price of this build comes in at £500.97 and I'm fairly certain it all works together. Is this a good build? Or are there cheaper parts I could use to bring costs down? I chose the motherboard because PC part picker alerted me to some issue with H81 motherboards and BIOS needing updated. I would get a H81 if I knew how to solve that issue! Also alternatively I noticed this video card: SAPPHIRE Radeon R9 270X Dual-X OC 4GB GDDR5 (£159.98 @ Novatech), Obviously 4>2, but is it worth the extra £30? I have no real preference for case only that I wish for it to be black and a bit understated (not really fussed on LEDs). Front USB 3.0 slots are not necessary but would be welcomed!
So what do you's think? Have I over estimated my requirements or do I have a build sufficient to cover my needs for the next few years?
Use that cpu, its not a K edition and isn't OC'able so I would still use it. If you are purely gaming then use an i5. The 270x will play BF4 on Ultra with an average around 50fps, and similar games although crysis 3 you might have to tone it back to just high settings. (If you really want spend the extra 100 pound and get a r9 280 http://www.novatech.co.uk/products/components/amdradeongraphicscards/amdr9280xseries/r9280x-dc2t-3gd5.html
I reccomend the Asus as even though it doesn't have the best performance it has the best cooling and is the quietest, so you sacrifice minimal performance for better cooling and a quieter card.)
Also go for the modular PSU, cable management for $4 is worth it. Trust me I didnt go for modular and regret it big time! And yeah the corsair are a great power supply but you can't really go wrong with any big name (antec, corsiar, seasonic etc) and always make sure it has an 80+ bronze rating at least.
Also with the next gen of games and 4k future proofing is a term that is hard to recommend, but yes it should play most games at reasonable frame rates over the next few years especially if you were to upgrade to a 280x.
Edit: The link you provided for your ram was out of stock. Heres the instock ram for same price http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16820313345&cm_re=ddr3_1600_8gb-_-20-313-345-_-Product
Thanks for the RAM link. That GPU looks great but spending an extra £100 is a bit of a push on my budget, but I will consider it. With 3 festivals this summer it's likely I'll have to stick to my £500 budget unless I can cut down on my expenditure when I'm away or sell some of the crap I've collected over the years on eBay.
Honestly the 270x will do just fine if you can't afford it. Like I said i've seen it average between 50-60fps with a minimum of 40fps in BF4 on ultra so i wouldnt really bother if money is tight to get a 280x, the 280x will just perform better in games in a year or two :)
Also do I need a sound card for this PC? I have no high-tech audio equipment and I will mostly be using HDMI as my video connection. I don't think I need a wireless card as I should be able to take one from an old PC I have in my house.
